81 Users Online (80 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Loadable Family Parameter Problem
Mon, Jan 16, 2006 at 2:16:20 AM | Loadable Family Parameter Problem
Steve1959
Using a standard window in Family Editor I added a brick sill and attempted to add a parameter that would allow me to vary the sills material once loaded into the project. The sill works well and adjusts to window width variations but I am unable to successfully add the material parameter. (Revit VShadey. I have followed the Revit Help instructions and also a Scott Onstot Video but am unable to pinpoint where I am going wrong. If someone could give me a clear and accurate step by step guide it would be greatly appreciated. Regards Steve (desperate new user)
Mon, Jan 16, 2006 at 2:34:10 AM | RE: Loadable Family Parameter Problem
eldados
eldados Avatar
4.5 Stars: 8 Votes
in the family editor click on your element and go to properties, under material and finishes you'll see "material" with a drop down box, to the right of this line there is a little box (do not click on the drop arrow, it is on the right of it) click on the little box, a dialog box appears called "associate family parameter" click "add parameter" give it a name like "sill Material" under "group prameter under" file it as a material and finishes and tick "Instance" load into your project, go to the properties and change the material to what ever you want. HTH
Integrator
KarelCAD
Mon, Jan 16, 2006 at 5:46:20 PM | RE: Loadable Family Parameter Problem
Steve1959
Many thanks eldados for parameter solution. Steve. Ballina NSW. (Nearly as much sun)
Mon, Jan 16, 2006 at 5:49:29 PM | RE: Loadable Family Parameter Problem
eldados
eldados Avatar
4.5 Stars: 8 Votes
that's cool Smile remember, you will need to change each and every window's material, or a handy way to put the same window once you changed it, is to right click on the window (in the project) and select "create similar"
Integrator
KarelCAD
Odd Family Behavior - Absorbing .RVT file info.
Wed, May 19, 2010 at 3:30:57 PM
Parameter names with dashes - problem with formula
Tue, Aug 31, 2010 at 10:28:40 AM
Parameter problem
Thu, Oct 22, 2009 at 10:14:19 AM
Creating Loadable Revit Families
Fri, Nov 27, 2015 at 4:52:03 PM
Trouble with Array Parameter within a nested family
Wed, Sep 12, 2012 at 5:19:17 AM
Page generation time: 1.9886
