Forums >> Revit Building >> Technical Support >> Existing Phase / Ceilings solid gray
Sun, Oct 14, 2012 at 3:37:19 PM | Existing Phase / Ceilings solid gray
COUGARBRENT
how come my ceilings appear solid gray when the phasing is set to Exisitng instead of showing the hatch pattern
help would be appreciated
Mon, Oct 15, 2012 at 12:40:18 PM | Existing Phase / Ceilings solid gray
Arrivalanche
I believe that it has to do with your phase filter or maybe your level of detail. I think I had that issue at points if the view wasnt set to show complete in the phase filter.
Phasing - how to have gray solid fill on existing walls
Tue, May 19, 2009 at 1:41:52 PM
HOW DOES ONE SHOW EXISTING CEILING GRID GRAYED OUT, AND THE NEW CEILING IN BOLD?
Fri, Aug 1, 2008 at 9:38:17 AM
Wall Pattern lost in Existing phase
Tue, May 27, 2008 at 2:08:45 PM
Walls set as existing not showing up in existing phase settings.
Sat, Aug 4, 2012 at 11:21:58 AM
Glass appears Solid in new Phase
Fri, Jan 4, 2013 at 6:07:39 AM
Page generation time: 0.6180
