Forums >> Community >> Newbies >> Yep! That's me
10 Posts No Rating |
The newbie I mean
So Hi guys just wanted to say that I recently moved on Revit from Autocad and one of the few things I haven't figure out is how to make projection lines in a hidden format... for example; when yoy make a stair, you found the steps in solid lines and then after the cut line the stair appears in hidden lines. How do I make to get the same to put a couple of hidden lines from a wall in adoor opening??
Thanks on advance
I cant get rid of this feeling that I found Revit too late... damn! Now extra turbo learning mode!!! |
Welcome to Revit's World...
use the "Show Hidden Lines" tool
Thanks Typhoon
But I think I didn't explain my self properly, so having a pic worth tousand words, here it is what I need, of course this is CAD drawing but shows the standard office representation...
Thanks again
Ohhh I see... you have to edit that door family and create those hidden symbolic lines like you want.
Ok I see...
But is just that... Detail lines right??
Thanks a lot again
''Visibility grafics'' and ''create parts'' problem when mak |
Fri, Mar 19, 2021 at 11:45:47 AM
Add ''scale'' on a drawing list, when it is not under ''available fiel |
Thu, Jan 12, 2012 at 8:35:33 AM
Split face on floor? |
Thu, Nov 17, 2011 at 2:28:27 PM
Time for goodbyes... |
Tue, Jul 20, 2010 at 1:47:22 PM
Im in! |
Thu, Apr 26, 2018 at 4:03:54 AM
Members: | 2115737 | Objects: | 23192 | Forum Posts: | 152301 | Job Listings: | 3 |
