Forums >> Community >> Newbies >> Adding new materials to my walls?
15 Posts No Rating |
In my ground template I have very few materials. For example I have some bricks but no red bricks wich are very common to houses.
How do I do if I want new materials? Is there anywhere I can download it? How do I get it work in the program?
You can download images off the internet and apply them as materials in the material library. Manage> Materials
But how about the scale. Will it be in correct scale?
Is there no other way ?
You can go into the materials library on your computers hard drive in the programfiles/RevitA or MEP or S
Is this the correct place to put the texture image? How do I then add it to my wall in Revit?
http://www.ladda-upp.com/bilder-a/revit-82.png
Edited on: Thu, Oct 11, 2012 at 2:56:03 PM
Create different folders to different categories material like "Concrete", "Wood", Bricks" and so on...
In this way you can create your own library....
Adding materials into Revit's materials files |
Thu, Jul 22, 2010 at 1:54:48 PM
Adding new materials to accurender library |
Thu, Nov 19, 2009 at 5:44:18 AM
Wish Match Properties tool worked while adding new walls or components. |
Tue, Apr 22, 2008 at 9:48:50 AM
Adding Materials |
Sat, Nov 24, 2012 at 7:30:55 PM
Adding New Materials to the Render Appearance Library in RAC 2009? [ 1 2 3 ] |
Fri, Aug 8, 2008 at 6:11:21 PM
31
Members: | 2115329 | Objects: | 23192 | Forum Posts: | 152320 | Job Listings: | 3 |
