84 Users Online (83 Members):
Forums >> Revit Building >> Technical Support >> Highlighting objects problem in 3D
33 Posts No Rating |
Hi All, I am having a problem....... I can work on the model in 3D and other views, and then all of a sudden when I switch back to 3D, the pick icon no longer highlights the objects to be selected and also the roof, walls and other objects, gradually change to wire frame the more I switch between views.
Have tried switching off "Hardware Acceleration" in case it has something to do with the graphics. I should say this problem is only unique to one particular model. The other projects are fine.
I am working using design options as I have with other projects and have never seen this before?? Has anyone else?
Would appreciate any help. Thanks in advance.
GN Brisbane, Q Australia |
I do know that you have to be in the design option set in order to select objects in that design option. as far as the
objects switching to wireframe, i am not to sure. If you are trying to select an object make sure you are in its current
design option set.
This does sound like a graphics card issue. Typically, if you delete the 3D view then create a new one, that will clear up the problem. But probably only temporarily.
Thanks for the comment. I should have said I am in the editing mode applicable to the design option. An example of what is happening is;
- Pick on roof in 3D veiw and click edit.
- make modifications as required, maybe switching between other "2D" views. Finish edit mode.
- Switch back to 3D and no longer able to hover over objects and have them highlight. Further switching between views further, makes the objects gradually transparent.
I would have to agree there seems to be a graphics card problem... however the problem is only with this project. I can have others open and do the same operations, with no problems.
My graphics card is aGeForce GTX 580 1.5GB
I will keep looking in to it and hopefully find what's going on.
WWHub.... just letting you know, I deleted the view and created a new one and have been working with it all day with no problems. Seems to be the answer, thanks for that it was getting a little annoying.
Toggling off highlighting |
Tue, Sep 25, 2012 at 1:05:28 PM
Placing objects in 2D, but cant see the in 3D. |
Fri, Jun 22, 2012 at 2:21:51 PM
Pre highlighting |
Tue, Mar 1, 2005 at 12:15:17 AM
Converting AutoCAD ACIS Objects (3D Solid) to Polymesh Objects |
Fri, Oct 12, 2012 at 7:31:58 AM
HELP! importing 3D objects cant be exploded |
Fri, Nov 10, 2006 at 10:48:19 AM
Members: | 2030550 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
