23 Users Online (22 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Cleaning Up Viewport Titles
Mon, Oct 1, 2012 at 2:37:43 PM | Cleaning Up Viewport Titles
leothelionator
Under Viewport Family Type Properties, you can add various types, but since it is a "System Family" it does not appear you can edit this family once a new viewport type has been added.  Is there any way to delete superfluous family types from the Viewport Family once they've been added?  It's like "You can check in any time you like, but you can never leave."
Mon, Oct 1, 2012 at 2:53:10 PM | Cleaning Up Viewport Titles
TKennedy
4 Stars: 7 Votes
Purge will get rid of them, as long as they aren't being used somewhere.
Mon, Oct 1, 2012 at 2:59:29 PM | Cleaning Up Viewport Titles
All except the main original one which can be modified and re-named.
Mon, Oct 1, 2012 at 3:01:46 PM | Cleaning Up Viewport Titles
leothelionator
I tried that and was unable to get rid of all of them.  Is there a way to query "select all instances" so I can locate the culprits?  I would normally do this by going to the Families in the Project Browser and right clicking on the specific family, but the problem is that I cannot see the Viewport Family anywhere in the project browser.
Mon, Oct 1, 2012 at 3:10:24 PM | Cleaning Up Viewport Titles
TKennedy
4 Stars: 7 Votes
Drop a view onto a sheet, then set it to the bad viewport type. Right-click, select all instances, then set them all to a good type. I just tried it in one of my projects, and it kinda works. It worked on a dummy type I just created, but not for one of they types that was already there that I wouldn't mind getting rid of. I don't know why, I suspect that it is either a system type, or that because it's in my template (which had it's beginning as an Autodesk template) Revit doesn't want to let me get rid of it. That or Revit is just being cranky again.
Mon, Oct 1, 2012 at 3:19:59 PM | Cleaning Up Viewport Titles
leothelionator
Thanks, that's a good idea.  Yes, I know for a fact that the default type cannot be removed regardless of whether it is being used.
Viewport Titles
Thu, Jun 30, 2011 at 8:19:48 AM
Multiple Viewport Titles in same sheet
Wed, Jul 30, 2008 at 7:16:18 PM
Purge unused Viewport Titles
Thu, Aug 30, 2018 at 10:41:49 AM
11
Viewport titles moving
Mon, Nov 10, 2008 at 10:16:48 AM
Viewport titles - how to modify them?
Sat, Feb 2, 2008 at 9:40:37 PM
Page generation time: 3.8071
