Forums >> General Discussion >> Revit Project Management >> How do you alter stairs in revit so that they could have a tread of 9" and riser
Fri, Sep 28, 2012 at 1:25:49 PM | How do you alter stairs in revit so that they could have a tread of 9" and riser
neonenvy
of 8"
I just go into the edit sereen and simply change them and I get:      The Actual Tread Depth for one or more Stairs violates the Minimum Depth set in the type.
Fri, Sep 28, 2012 at 1:27:53 PM | How do you alter stairs in revit so that they could have a tread of 9" and riser
Change the allwable traed / riser settings in the stair type.
Stairs: Hide Tread and Riser in Section View
Mon, Mar 11, 2013 at 8:36:41 AM
How to model a non-typical length stair tread for the top tread
Mon, Jan 25, 2016 at 1:55:19 PM
adjusting spacing while using "Use Baluster Per Tread On Stairs"
Tue, Sep 1, 2015 at 4:10:58 PM
Stair Riser/Tread Number in Multistory Stairs
Tue, Sep 13, 2016 at 9:47:54 AM
non typical stairs
Wed, Jul 16, 2008 at 1:03:16 PM
Page generation time: 2.6831
