105 Users Online (104 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Extreme Slope at Roof Edge After Attaching Roof to Beams Using "Pick Supports"
Fri, Sep 28, 2012 at 8:48:14 AM | Extreme Slope at Roof Edge After Attaching Roof to Beams Using "Pick Supports"
cboersen
Revit 2013:
For making roofs I want to attach my roof to the roof structure to have the roof match the beam slope. So in the roof contextual modify panel I select "pick supports" which attaches the roof to the beams - perfect. The problem I am having is that the beams are about a foot from the edge of the roof and the roof edge maintains its original height and not the slope of the beam so you get this extreme slope at the perimeter (see attached PDF). How do you fix this, or am I going about this incorrectly?
Fri, Sep 28, 2012 at 10:43:54 AM | Extreme Slope at Roof Edge After Attaching Roof to Beams Using "Pick Supports"
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Have you tried to modify the sub elements around the perimeter and change them to the elevation you want?
Fri, Sep 28, 2012 at 11:58:24 AM | Extreme Slope at Roof Edge After Attaching Roof to Beams Using "Pick Supports"
cboersen
Yes, but you have to have the slopes identical (which is almost impossable) or you still get a little hump.
Sloped Roof Edge
Tue, Jan 17, 2006 at 8:57:30 AM
Roof slope line incorrect
Wed, Sep 30, 2009 at 6:28:38 AM
Roof and constructional roof beams!!
Thu, Apr 13, 2006 at 8:11:40 AM
Attaching beams to model by face roofs - limitations?
Tue, Oct 13, 2009 at 1:46:26 PM
Joining Roof By Extrusion
Mon, Jan 31, 2011 at 8:15:15 AM
Page generation time: 2.9047
