77 Users Online (76 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Workflow & Implementation >> API & Third Party Apps >> Changing Stair Tread Shape
Wed, Sep 26, 2012 at 1:08:51 PM | Changing Stair Tread Shape
ewhipple
I designed a straight run stair that has circular treads. I know how to change the nosing shape, but i don't know how to change the shape of the actual tread. Is this possible?
Wed, Sep 26, 2012 at 1:22:25 PM | Changing Stair Tread Shape
Check out this thread:  http://www.revitcity.com/forums.php?action=viewthread&thread_id=28325
Wed, Sep 26, 2012 at 2:00:53 PM | Changing Stair Tread Shape
ewhipple
I looked at that thread, but it deals with a different issue so it doesn't really help. Thanks anyway, though.
Wed, Sep 26, 2012 at 2:18:31 PM | Changing Stair Tread Shape
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
What are you trying to change the tread to look like?
Wed, Sep 26, 2012 at 3:11:30 PM | Changing Stair Tread Shape
Well.... we can't read your mind ... and I think the other threads solution is possibly still yours ... but since your not more descriptive....
Wed, Sep 26, 2012 at 3:28:44 PM | Changing Stair Tread Shape
ewhipple
I'm trying to make it so that when you look at it from above, the treads are circles. Each tread is a flat, 3' diameter, 1 1/2" thick circular disk. If anyone knows how I can make that happen (or if you have more questions about my design) please let me know. Thanks!
Wed, Sep 26, 2012 at 4:15:18 PM | Changing Stair Tread Shape
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
How is this stair held up?  Do you have something you are going off of?  You can create a half circle tread as I have attached, but I am not sure on how to make a whole 3' diameter tread.  You would have to get creative with railings or in-place components to achieve this I believe.
Edited on: Wed, Sep 26, 2012 at 4:16:39 PM
Wed, Sep 26, 2012 at 4:16:25 PM | Changing Stair Tread Shape
As I suspected - The previous link is still an answer.  The only chage is how you create the tread family.  IKn your case, it is an extrusion or an extrusion plus a sweep in a plan view.  << (Depends on the riser profile)
Wed, Sep 26, 2012 at 6:33:54 PM | Changing Stair Tread Shape
ewhipple
@teafoe5:
The stair is held up by a single steel carriage (a 6" by 7" rectangular steel tube). It has no stringers or risers. The stair you attached is very similar to what I want, but I need the treads to be the full 3' circle because that way when you look at them in section, the treads extend further underneath the other stairs. i attached a screenshot of a SketchUp model I built of the stair. (There are railings on both sides but I hid one so you could see what the stair looks like).
@WWHub:
I am not really familiar with using families, but if that thread has enough info on how to do what I need to do, then I'll definitely take a closer look at it.
Thu, Sep 27, 2012 at 9:21:38 AM | Changing Stair Tread Shape
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
The thread that WWHub pointed out will be useful to you and should answer your questions.  Check out the video that he posted.
How to model a non-typical length stair tread for the top tread
Mon, Jan 25, 2016 at 1:55:19 PM
Stair Riser/Tread Number in Multistory Stairs
Tue, Sep 13, 2016 at 9:47:54 AM
Custom Stair Tread Profile vs. Default Tread Profile
Tue, Apr 30, 2019 at 2:28:08 PM
Baluster per tread on curved stair
Thu, Apr 4, 2013 at 2:18:52 PM
Stair Tread Surface Pattern
Tue, Feb 8, 2011 at 1:56:42 PM
Page generation time: 3.7558
