Forums >> Community >> The Studio >> Filter Overrides
Hi guys, I got a question for you all: Is there a quick way to pass the overrided color applied to a filter, to the same filter applied to other view?
I believe you can do that using a view template.
Well, your believe was right. It worked. Although you must change a couple of settings after applying the template: The discipline and the rvt link visibility. Thank you very much for making me realize what was the obvious procedure.
Edited on: Wed, Sep 26, 2012 at 9:42:43 AM
If you do not see freelinking working at all. There must be some conflict with other input formats. Try first to disable all other input formats and only leave Freelinking activated. Clean the cache and then test editing a node with a freelink and save it. If it works, try adding other input formats until you get to the right order in which they have to be in order to work correctly.
scrapbooking |
You can set your view template to only apply the VG settings for filters, that way you don't have to go back and change the discipline and link settings.
I love this community. Thanks a lot Mr Kennedy. Just for confirmation, you mean unchecking this? (attached image)
Filter by Phase |
Thu, Apr 15, 2010 at 10:37:35 AM
Phase Graphic Overrides |
Wed, Jul 10, 2019 at 4:01:46 PM
Visibility Graphics/Overrides COMPLETELY grayed out. Revit Structure 2013. |
Tue, Mar 27, 2018 at 3:22:43 PM
Filter turns everything off |
Wed, Apr 19, 2017 at 9:25:55 AM
Rendering |
Sun, Oct 31, 2004 at 4:35:08 PM
Members: | 2116465 | Objects: | 23196 | Forum Posts: | 152303 | Job Listings: | 3 |
