79 Users Online (78 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> fill patterns
Thu, Jan 12, 2006 at 11:22:03 AM | fill patterns
hammer87
hammer87 Avatar
3 Stars: 4 Votes
i was wondering how do you download and import fill patterns? ive tried to download befor, but when it downloads it as a text documant
Thu, Jan 12, 2006 at 11:42:23 AM | RE: fill patterns
sfrazier
Hammer87, Once you download the fill pattern which is a .pat file. you have to go to your fill patterns in Revit under the settings pulldown list and import it into revit. The process for that is, once fill patterns is open, click new select draft - this reason for that is that most fill patterns are 2d-. Then select import- navigate to your pattern and set the scale... Remember to immediately set the scale because once it's set you can't change it unless you reimport it under a new name. I usually name my fills by scale and type e.g. 1/32 diag... Hope this helps... Shaun
Thu, Jan 12, 2006 at 12:42:51 PM | RE: fill patterns
hammer87
hammer87 Avatar
3 Stars: 4 Votes
ok thanks ill try that.
Perpsective Fill Patterns
Mon, May 10, 2010 at 6:12:50 PM
Fill Patterns
Mon, Mar 10, 2008 at 6:40:09 AM
create/ convert hatch patterns (.pat) to revit fill patterns
Tue, Jun 2, 2015 at 11:29:00 AM
Fill patterns, where are they?
Tue, Mar 31, 2009 at 10:11:29 AM
Wall Fill Pattern question
Tue, Oct 23, 2012 at 8:39:37 AM
Page generation time: 0.5122
