27 Users Online (26 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> Connecting Sanitary Piping
Tue, Sep 25, 2012 at 8:28:48 AM | Connecting Sanitary Piping
jawatts4
I've been trying to figure out a simple way to connect all of the sanitary piping I have on a project.  Particularly when I have a 3 pipe connection.  Anyone have any savvy tips that might make this easier.  It's very difficult when the piping slopes and the routing solutions aren't the greatest.
Thu, Oct 4, 2012 at 9:56:58 AM | Connecting Sanitary Piping
Gyvven
5 Stars: 2 Votes
Properly built fittings will likely fix your problem. I've found that there are some good manufacturer created fittings, and some very bad ones that require a lot of adjustment to make them work properly. A lot of the OOTB fittings work great but aren't dimensionally accurate to what is manufactured, that's why we went to either in-house or manufacturer created fittings. I'm not entirely sure if this is what you're looking for but it sounds like it.
We also try and steer clear of sloping pipes, even though Revit has come a long way with this. We'll do it if there are concerns about collisions, but most times we can avoid it. I've also found that connecting to a horizontal pipe and then sloping it tends to work better for routing solutions.
HTH and isn't too late.
Gyv
Fri, Dec 7, 2012 at 11:30:00 AM | Connecting Sanitary Piping
kmeasamer
Has anyone had troublke with the 45 degree connection in sanitary pipe. I will try to connect the pipes together and the connection automatically turns the opposite way.  Is there an order you have to connect sanitary piping?
Fri, Dec 7, 2012 at 12:29:51 PM | Connecting Sanitary Piping
Gyvven
5 Stars: 2 Votes
kmeasamer,
I'm guessing that the attached image is what you're referring to with Sanitary Tee connections.
I've found that if you get the acute sanitary connection, simply erase the fitting and select the downstream pipe, drag it's connector to the upstream pipe and use "Trim/Extend Single" (TS) command to attach your branch and it should connect with the proper  angle. Try this with the upstream pipe segment and you'll get the acute angle again. It's a bit of a pain, but at least it'll look right.
I'm not sure if this has anything to do with Element IDs and the Primary connector, but it might. I've found the Primary connector likes to attach to the lowest Element ID when it can. I discovered this behavior when I was building a P-trap fitting and the trap would insert sideways, like a b. I found it made a difference which pipe was drawn first, the horizontal or the vertical.  If the vertical was first it would work because the Primary connector was on the top of the trap. I re-assigned the Primary connector to be the outlet or horizontal since I generally draw that pipe first in my workflow and everything worked out great.
HTH,
Gyv
Thu, Dec 13, 2012 at 3:42:24 AM | Connecting Sanitary Piping
joseph02
hi everyone
Thanks for sharing information,its really helpful.
Pipe systems getting cross connected
Mon, Dec 21, 2020 at 7:39:26 AM
SANITARY WALL CLEAN OUT
Tue, Jan 26, 2010 at 10:39:25 AM
Specific piping systems in Revit MEP
Wed, Sep 30, 2009 at 6:37:30 PM
Pipe disappears after connecting to unit
Sun, Aug 23, 2009 at 2:51:51 PM
Red lines around piping, System types
Mon, Jun 8, 2009 at 4:45:44 PM
Page generation time: 0.3341
