62 Users Online (61 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> sweep line weight in elevation
Mon, Sep 24, 2012 at 9:27:52 PM | sweep line weight in elevation
Gehrys
see the attached file, the FRP sweep lines in the interior elevation should be the same or thinner than the grab bars.  I cant seem to get them to go thin.
Tue, Sep 25, 2012 at 2:22:44 PM | sweep line weight in elevation
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Use the linework tool and change them to a thinner line.
Tue, Sep 25, 2012 at 6:52:46 PM | sweep line weight in elevation
Gehrys
Ah, but see how the lines are through the grab bar now.
Wed, Sep 26, 2012 at 7:18:47 AM | sweep line weight in elevation
When you use the linework tool, you will see a node on the end.  Before you continue, grab that node and drag it to where you want.  In this instance, you would do it for both sides.
BTW - make sure you have your object syles set to what you really need.  That is what contols these lines.
Wed, Sep 26, 2012 at 9:02:50 AM | sweep line weight in elevation
Gehrys
I did find that if I set the walls projection lines override to 1 the sweeps look correct.  Is overriding the walls lineweight going to effect somewhere else that i'm not thinking about?
Wed, Sep 26, 2012 at 9:11:35 AM | sweep line weight in elevation
You can set per view in VG if you don't want the object styles, project wide setting.
Wall sweep line weight
Tue, Apr 24, 2012 at 2:58:40 PM
elevation tag line weight
Wed, Dec 17, 2008 at 1:55:40 PM
Model Text line weight override...
Wed, Dec 18, 2013 at 9:47:46 AM
Line weight in family doesn't equal line weight in project
Fri, May 31, 2013 at 2:54:30 PM
Line Weight as Family Parameter
Fri, Mar 16, 2007 at 4:23:59 PM
Page generation time: 24.2635
