Forums >> Revit Building >> Technical Support >> Corner guards to snap to corner of wall
5 Posts No Rating |
I've downloaded a couple of corner guard families but it seems like the piece only snaps one leg of it to the face of the wall, and not the corner. What ends up happening is that, instead of rotating to accommodate the corner configuration, the corner guard now shows up embedded into the wall. Please see attached jpg) Is there a way to create an "axis hosted" or "line hosted" family, so that it will snap to the corner of the wall? Thanks in advance!
That corner guard family needs a flipper added then jut dag it over to the corner.
You can do what WWHub said, and/or change the insertion point ref planes so the are where you want them to be.
TKennedy,
Are you suggesting ref planes at the corner of every wall... or 2 ref planes at ea corner? .... really?
5 Posts No Rating |
Hi WWHub and TKennedy! Thanks for your suggestions.
I've changed the insertion point to where I want it to be, so now the origin is in the correct spot when I insert it, but how do I add a "flipper" or something that will rotate it into the correct orientation?
Jeanie
Edit the family to insert the flipper.
I have a corner guard family that might work for you
Jason Wells
"The People Who Are Crazy Enough To Think They Can Change The World Are The Ones Who Do" Steve Job |
5 Posts No Rating |
Hi,
Thanks for the family. Would you mind saving it to R2013? It seems like it was created by a newer version. Thanks!
Jeanie
You can not save Revit back to 2013 i'd have to recreate it
Jason Wells
