50 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Backwards Crop Box on Interior Elevation
Mon, Sep 24, 2012 at 11:37:32 AM | Backwards Crop Box on Interior Elevation
leothelionator
I'm using Revit 2012 and we recently made a major design change that involved rotating the building 45 degrees.  Most of the glitches have been resolved with the exception of one interior elevation which is pointing backwards.
See attached image.  Notice anything peculiar, such as the fact that the elevation indicator is pointing to the upper right but the crop box is pointing to the lower left?  I cannot rotate it (at least without messing up all the other interior elevations) and if I try to slide the crop box in the opposite direction, it stops at the zero distance line.  Please help.
Thanks.
Mon, Sep 24, 2012 at 12:16:40 PM | Backwards Crop Box on Interior Elevation
I would create a new, temporary, elevation and transfer all symbollic elements to that.  Then you can delete the old view and then check the box to create a new one pointing in the correct way.  Then transfer your elements again and delete the temp view.
By the way, , you can also place the new temp elevation on the correct sheet and just drag that overtop your old one (after deleting the bad view) and it will appear correct.  It will just be 2 callouts.
Mon, Sep 24, 2012 at 1:42:52 PM | Backwards Crop Box on Interior Elevation
leothelionator
Thanks, that seems to be the most straightforward answer when dealing with a corrupt elevation.
Mon, Sep 24, 2012 at 1:50:29 PM | Backwards Crop Box on Interior Elevation
BTW.  Instead of rotating your model, you may have been better off to rotate the project.
Mon, Sep 24, 2012 at 2:02:32 PM | Backwards Crop Box on Interior Elevation
leothelionator
I would have, but it was only a partial rotation of one building within a building complex.
Elevation Crop Box Stretches backwards?
Mon, Jun 9, 2008 at 8:54:11 AM
Interior Elevation Crop boundries
Thu, Aug 13, 2009 at 12:13:24 PM
Can Interior elevation view box not be a square?
Fri, Jun 10, 2011 at 12:52:29 PM
Revit 2013- Adjusting the default setting for Interior Elevation crop boundary?
Mon, Aug 26, 2013 at 4:23:48 PM
Crop Regions Disappear When I Assign a View Template
Sun, Apr 22, 2018 at 11:04:20 PM
Page generation time: 1.1309
