44 Users Online (42 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Toposurface & Pads
Thu, Sep 20, 2012 at 5:38:52 PM | Toposurface & Pads
jarmstrong
I have drawn my toposurface as new construction and then put a building pad over it as new construction. When i do so, i cannot see the contour lines under where my building pad has cut the topo. Can i put the building pad in a 'future' stage or something so that i can see my contours in this view? File attached for reference!
Fri, Sep 21, 2012 at 9:54:44 AM | Toposurface & Pads
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I don't believe there is a way to do this using a building pad.  The building pad is actually cutting the toposurface so in reality the lines dont run through it.  The only way I think you are going to be able to achieve this is to use a floor slab instead of a building pad and turn the transparency up on the floor slab so that the topo lines will show through.  The only problem with doing it this way is that a floor slab will not cut the topo surface.
Edited on: Fri, Sep 21, 2012 at 9:55:42 AM
Adjacent building pads: toposurface popping up between
Wed, Nov 20, 2013 at 10:22:59 AM
Topo PADS
Sat, Sep 29, 2007 at 3:41:40 AM
Toposurface Issues
Wed, Mar 28, 2012 at 1:50:09 PM
Toposurface&subregion problems
Thu, Apr 16, 2009 at 1:47:06 AM
CUT AND FILL - PADS WHICH DO NOT SHOW C&F VOLUME ON A SCHEDULE
Tue, Feb 13, 2018 at 4:37:06 AM
Page generation time: 1.3239
