46 Users Online (45 Members):
Forums >> Revit Structure >> Technical Support >> Walkthrough Key frame Levels Change Revit 2012
Is there a way to change my key frame levels after the walkthrough is created?
While I am creating my walhthrough I can select the level I want my camera to be placed. After viewing it I noticed that I would get a better result if I could change my camera level for my frames 8 through 12 for example.
How can this be done?
Thank you.
I also have that same question. But I have done a "work around" for it. Not ideal, but it gets the job done. Insert a building section where your 8 - 12 frames are. Then go and click open your walk thru in the browser. Highlight the cropped area and click edit walk thru. Switch to your building section and you will see the elevation path (in blue see attached jpeg) of your walk thru. At the top click modify/cameras. Then go to your options bar and under controls switch from active camera to path. Then you can select the round blue circles in the path. Move them up or down.
Hope that helps you out somewhat.
I also found this (see attached)
Walkthrough - 3D orbit/change levels |
Fri, Sep 19, 2008 at 6:04:56 AM
Revit Walkthrough; between key frames |
Thu, Jul 30, 2015 at 8:22:01 AM
How change levels in a walkthrough? (walking from 1st to 2nd story) |
Mon, Dec 14, 2009 at 7:07:33 AM
walkthrough rendering frame counter? |
Thu, Aug 20, 2009 at 10:50:49 AM
Adjusting height of key frames in walkthroughs |
Mon, Aug 1, 2011 at 2:18:11 PM
Members: | 2022374 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
