37 Users Online (36 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> CLASSIC MATERIALS EDITOR
Wed, Sep 19, 2012 at 4:31:45 PM | CLASSIC MATERIALS EDITOR
tomsheridan
I would like to proclaim the Revit 2013 materials editor a P.O.S! Goes real slow and is the culprit of many crashes I've had since upgrading to 2013.
P.O.S!
End of rant.
Wed, Sep 19, 2012 at 5:11:49 PM | CLASSIC MATERIALS EDITOR
tomsheridan
Also, when in the materials editor, and theres the preview of your material, usually the preview is very dimly lit and is never a realistic representation of what the material really looks like when you apply it then render.
Can you turn n a light in the previews or something?
Sat, Oct 20, 2012 at 8:46:29 AM | CLASSIC MATERIALS EDITOR
LindsayMollenhauer
Likewise,  I am creating a new 2013 drawing template to suit my needs  from the standard 2013 Architectural Template, nothing complicated.My machine is a Intel I7 with 16GB memory, very standard & uncomplicated.I have created a new Material (different kind of grass) by duplicating something similar and then trying to assignone of the standard Material Render Appearances to it.  Revit crashed when I try to close the dialogue box.I read that Autodesk is offering solutions like reinstall Revit, do this and that in  Windows.Rubbish!  I am not going to muck around with my Windows 7 Professional 64!    It runs everything else perfectly!Autodesk, you do your own thorough testing, I am not going to do it for you!Revit 2009 was great, then the rot set in!  you better get it right for Revit 2014, I am starting to loose faith!
Sat, Oct 20, 2012 at 10:54:50 AM | CLASSIC MATERIALS EDITOR
LindsayMollenhauer
Just installed 2013 Update 2 build (20121003_2115) (64-bit).   It appears to fix my previous problem.I still remain unconvinced that Autodesk can deliver a relatively  bug free upgrade every year.Every 5 years for a new release would be more realistic.
By the way,  when installing Update 2, it just sits there and appears to do nothing for 10-15 minutes, then continues.
Sun, Oct 21, 2012 at 6:41:21 AM | CLASSIC MATERIALS EDITOR
4 Stars: 202 Votes
"By the way,  when installing Update 2, it just sits there and appears to do nothing for 10-15 minutes, then continues."  - I updated my Revit 2013 (2013 Update 2 build (20121003_2115) (64-bit)) and it took only 10 seconds...
slow materials editor
Mon, Apr 15, 2013 at 7:59:27 AM
No Materials in Family Editor?
Tue, Jun 16, 2009 at 8:23:26 AM
Materials Editor
Wed, Mar 18, 2009 at 11:43:56 AM
Materials Bitmap Editor needs to be created
Sun, Jan 29, 2006 at 4:25:45 PM
2010 classic [ 1 2 3 4 5 ]
Thu, Apr 8, 2010 at 9:25:31 AM
68
Page generation time: 1.5934
