47 Users Online (46 Members):
Forums >> General Discussion >> Revit Project Management >> Internal Wall Finishes
Could someone please advise on the best way to show internal wall finishes in plan?
In Autocad we normally show different line styles in different colours which represent the different finishes, and a key. Is it done similar in Revit?
We use a finish tag with leader(s) in both plans and elevations. You can use the leaders to show the limits of the finish in plan.
Thanks, would you mind explaining to me how I create a finishes tag
We just used a generic annotation template to create our tag. The finish is type driven so all instances can be found and changed or replaced.
![iamian33 Avatar](user_avatar/135203.jpg)
148 Posts No Rating |
WW.
I am trying to follow thru with this suggested approach but I am unable to create the FINISH TAG. I have a Generic Annotation tag and assigned it to the Material tags category, thinking that I would use Comments, or Description to deliver the Paint code (P2). This works well in elevation but oddly in plan.
Can you clarify your tag creation? And also, are you able to show multiple arrows/leaders in plan? I've not been able to duplicate your efforts. I hope that you can guide me with this old thread.
Ian
Ian Shafer
Principal Consultant
True North S&F Consultants |
Creating a wall finishes schedule, and coding wall finishes on elevations |
Fri, Jun 1, 2012 at 4:06:32 PM
wall finishes by room |
Tue, Apr 19, 2005 at 11:40:25 AM
Wall finishes and grade |
Tue, Aug 31, 2010 at 12:33:10 AM
Multiple Wall Finishes. |
Thu, Dec 12, 2013 at 11:02:29 AM
Wall interior finishes - new wall type or a better way? |
Tue, Mar 8, 2005 at 1:07:59 PM
Members: | 2022361 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
