95 Users Online (94 Members):
Forums >> Revit Structure >> Technical Support >> Multi-category lenght & volume parameter
3 Posts No Rating |
Hello.
When creating a structural column, beam, connection element schedules I can get the steel tonnage by using the
length, volume and W parameters, but in the multi-category schedule I do not have the volume & length parameters.
Is there a way to import them or any other sollution, so I can have all my steel elements in one schedule?
Thank you.
You would need those shared parameters assigned to your other elements that would be scheduled. But obviously they would not populate and therefore would not calculate in the tonnage.
Edited on: Tue, Sep 18, 2012 at 8:39:19 AM
Creating a wall tag with a volume parameter |
Sun, Jun 23, 2013 at 3:56:03 PM
Space "number" parameter to Multi-Category Tag? |
Fri, Dec 13, 2013 at 10:26:02 AM
Shared parameter shows up in Multi Category Schedule But not in Conduit Run type |
Mon, Jan 6, 2014 at 2:27:49 PM
Having Trouble with Multi-category tags |
Wed, Jun 20, 2007 at 12:43:08 AM
Problem with Multi Category tag |
Mon, Apr 3, 2006 at 12:48:41 AM
Members: | 2017072 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
