56 Users Online (55 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> Newbies >> Building Symmetry Shortcuts
Mon, Sep 17, 2012 at 9:51:06 AM | Building Symmetry Shortcuts
Jimmybebop
If anyone has input/suggestions for shortcuts related to dimensioning building symmetry, I would be interested. Ex. in Autocad, I would dimension one side of a symmetrical building and mirror the dims. to the other side. This was a huge time saver, but this doesn't seem to work in Revit.
Mon, Sep 17, 2012 at 9:57:07 AM | Building Symmetry Shortcuts
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Personally I do not "double up" on dimensions.  If one side of your building has the same dimensions as the other I would only dimension one side.  I do not believe there is a shortcut to dimensioning the way you are looking for.
Mon, Sep 17, 2012 at 10:16:49 AM | Building Symmetry Shortcuts
AutoCAD was just 2D so you could do that.  You can do it in revit too (mirrored about the witness point) but the witness lines will goto where you set them in your original dimension.  Probably not a good thing.  Just mirror them, then before finishing, drag them to your other side of the building
This is really not a disadvantage.  There are so many advantages that you will so disregard this.
Mon, Sep 17, 2012 at 11:12:31 AM | Building Symmetry Shortcuts
Jimmybebop
Thanks for input. When you "just mirror them and then drag.." what are you mirroring about?
Mon, Sep 17, 2012 at 12:04:06 PM | Building Symmetry Shortcuts
Use the mirror tool that allows you to "draw" the mirror line.  As I said though, that does't matter because the mirror point will be the end of the witness lines.
keyboard shortcuts
Mon, Oct 18, 2010 at 9:53:11 AM
Some Keyboard shortcuts not working?
Tue, May 5, 2009 at 2:52:55 PM
Keyboard shortcuts
Thu, Jul 3, 2008 at 11:14:44 AM
Keyboard Shortcuts Won't Open/Show
Tue, Feb 26, 2013 at 11:09:04 AM
Keyboard Shortcuts??????
Thu, Jun 12, 2008 at 9:19:18 AM
Page generation time: 4.9080
