64 Users Online (62 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Rendering and Ray Tracing issues Revit 2013
Mon, Sep 17, 2012 at 5:19:23 AM | Rendering and Ray Tracing issues Revit 2013
mightymouse2045
Hi,
I am new to Revit and am having an issue where Ray Tracing an interior shows up black, where as if I render the same view it renders the sun and interior lights correctly?
I have set the graphic and render settings to the same - interior sun & artificial and anything else I can think of but it's just not doing it.
Am I missing something or is this a bug?
Also while I'm at it - can anyone help me with the shadows as shown in the rendered pic - it just makes the walls look dirty, is there a setting or something I can adjust to fix that up?
Thanks for any help with this Smile
MM
Mon, Sep 17, 2012 at 10:07:51 AM | Rendering and Ray Tracing issues Revit 2013
carrucha75
carrucha75 Avatar
4 Stars: 24 Votes
Hi! have you tried changing the sun setting while being in Ray Trace view different thing if you change it when being in realistic.
Not Sure What Revit Can Do?... Find it OUT!!!
Imagination is more important than knowledge...” -Albert Einstein
Thu, Sep 27, 2012 at 10:17:33 PM | Rendering and Ray Tracing issues Revit 2013
mightymouse2045
Hi - I hadn't done that - I managed to get it working now, thanks for the tip.
I found also that the sun works better when the background is set to sky and the ground color is something lighter than the default grey.
Fri, Sep 28, 2012 at 3:23:40 AM | Rendering and Ray Tracing issues Revit 2013
Polar
Hight MM,
It seemed like light fixtures rendered correctly for me in the file on the computer, but then when rendered online errors in light fixture geometry became appearant. Errors like the light source being above parts of the fixture that kept the light from coming out and lighting up the room. It looks like you may be having a similar issue where the interior  lights just aren't coming on for you.
Are you using revit light fixtures or content made by the manufacturer?
Is there an IES web file assigned to the light(s)?
think it - build it
Ray Tracing
Thu, Jun 28, 2012 at 6:10:25 AM
Metal Ray as rendering engine for Revit
Fri, Apr 25, 2008 at 7:31:10 PM
Ray trace Disabled in Revit 2013
Thu, Apr 4, 2013 at 5:47:34 AM
Mental Ray rendering questions
Mon, Oct 13, 2008 at 12:37:55 PM
Revit 2013 Rendering mass issues
Wed, Mar 20, 2013 at 10:56:42 AM
Page generation time: 2.7637
