Forums >> Revit Building >> Technical Support >> Section Head colour
208 Posts No Rating |
Hi all,
I can't seem to manipulate the pen settings for my section and callout heads.
I have manipulated the settings within the 'object styles' menu to what I would like however, these settings do not carry through. The heads all remain blue.
What else is there to check?
cadjockey
Have you tried opening the section head family and editing it. I'm not 100% sure but it may help.
Puzzle
Macca Sunshine Coast QLD Australia |
So you not trying to change the lineweight just the color
Blue in revit indicates its hyperlink. In your print settings there is an option to print these as black.
Hi puzzle,
I have created a custom head which I have loaded into the project. The font and size of the head is fine. Just as I have created it.
When in the project the entire head shows up as blue despite adjusting the visibilty and object style settings.
I tried assigning a line type within the family that has the settings I am looking for however, there is no option to select or load any other line types into the family. Other than 'invisible lines'
cadjockey
Hi Mr Spot,
No I am also trying to manipulate the pen weight as well.
I was aware of the print setting option. I have used it within my session settings.
cadjockey
Trying to Import Filled Section Head |
Mon, Jun 27, 2016 at 2:32:45 PM
problem with section head |
Sun, Nov 26, 2006 at 4:49:05 PM
Section Head |
Thu, Nov 11, 2010 at 2:21:51 PM
Section Head |
Tue, Jun 18, 2013 at 11:22:52 AM
Section Head with Typical |
Tue, Jan 29, 2019 at 8:18:27 PM
Members: | 2105050 | Objects: | 23178 | Forum Posts: | 152306 | Job Listings: | 3 |
