48 Users Online (46 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> In shading w/edges mode, inserted window do not cut out of wall in plan view..
Wed, Jan 11, 2006 at 4:27:36 PM | In shading w/edges mode, inserted window do not cut out of wall in plan view..
pedersen
How do i control this? see attached image
Wed, Jan 11, 2006 at 5:49:21 PM | RE: In shading w/edges mode, inserted window do not cut out of wall in plan view..
eldados
eldados Avatar
4.5 Stars: 8 Votes
could be 2 things: 1: your window family is not right, you might have to edit the family 2: you might need to adjust your view range and get the cut plane through the window (I think this will be the problem) HTH
Integrator
KarelCAD
Thu, Jan 12, 2006 at 4:28:28 AM | RE: In shading w/edges mode, inserted window do not cut out of wall in plan view..
pedersen
this problem occures with every window i insert,also the standard windows that ships with revit. in 3d view everything is ok. i'v checked the view properties , and cutplane is at 1200mm. When sill height is set to 0mm, it displays correct in plan view. Pedersen
Shading with edges in Plan View
Tue, Dec 1, 2009 at 9:15:30 AM
Problems plotting "shading with edges"..................
Mon, Mar 24, 2008 at 8:01:10 AM
Why is 3d transparent although I have shading with edges selected in RAC2008 [ 1 2 3 ]
Mon, Jul 28, 2008 at 10:02:02 PM
30
shading with edges problem
Wed, Nov 17, 2010 at 6:49:50 AM
viewing structural, architectural & hvac in 3d with shading and edges
Tue, Apr 20, 2010 at 5:53:59 AM
Page generation time: 1.9704
