85 Users Online (84 Members):
Forums >> Community >> The Studio >> system without ducts
Hi, can anyone tell me how can I make my exhoust system (supply too) to work in the case when the architecture itself IS part of the path of the airflow. I'm talking about the case of "plenums", those little rooms for filters, through which the air passes, without being a duct actualy. I have been thinking of an "in place component" with no objects but only the connectors. Would it work?
You might try using sections of duct in the plenum spaces and then hiding them in the view. The system remains intact if you do this (you can select one part of the system and tab until the entire system is selected, including the parts on the other side of the hidden duct) so I believe you shouldn't lose any information on either side of the hidden elements.
jlights |
system type in ducts |
Mon, Sep 24, 2012 at 11:55:48 AM
Need to change material on ducts. They are rendering as black masses? |
Thu, Jun 11, 2009 at 12:14:39 PM
dual duct supply |
Sun, Oct 18, 2009 at 6:51:07 PM
QUANTITY TAKEOFF FOR DUCTS |
Mon, Apr 21, 2014 at 7:33:52 AM
military requirement |
Mon, Aug 18, 2008 at 3:54:42 PM
Members: | 2017442 | Objects: | 22947 | Forum Posts: | 152208 | Job Listings: | 3 |
