132 Users Online (132 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Turning off wall base feature in Case Work family
Tue, Sep 11, 2012 at 12:52:08 PM | Turning off wall base feature in Case Work family
PaulM3357
Is it possible to turn off the wall host setting in wallbased casework family?
Any comments will be appreciated.
Thanks! in advance.
Tue, Sep 11, 2012 at 12:58:39 PM | Turning off wall base feature in Case Work family
Warchitect
4 Stars: 5 Votes
I dont think so. but you could copy and paste the parts into a new non-wall based family.
Tue, Sep 11, 2012 at 1:20:44 PM | Turning off wall base feature in Case Work family
I haven't heard anything different about 2013 but in all other releases, you can't copy from family to family.
I think you will be stuck in creating a new family.
Fri, Sep 14, 2012 at 9:12:38 AM | Turning off wall base feature in Case Work family
PaulM3357
Thanks WWhub!
It seems that there are no other options available, I think that's what I need to do.
Best Regards,
Fri, Sep 14, 2012 at 11:26:45 AM | WWHub
TKennedy
4 Stars: 7 Votes
Quoting WWHub from 2012-09-11 13:20:43
You can copy/paste from family to family and project to project, you just have to keep both files open. You can also copy in-place family to another family as long as you are editing the in-place family when you copy, and keep the project open when you paste.
Fri, Sep 14, 2012 at 11:30:05 AM | Turning off wall base feature in Case Work family
TKennedy
4 Stars: 7 Votes
I forgot to add, when you C&P between families the pieces will often lose their association/locks to ref planes. It's pretty easy to fix, but it's definitely something to watch for.
exploded views and sheet feature in revit family editor
Mon, Mar 24, 2014 at 10:55:31 AM
Wall Base Offset... one works, one doesn't. Why?
Wed, Jun 10, 2015 at 2:53:53 PM
Wall Base/ Wall Sweeps and Door "Clipping/Cutting" RVT 2014
Fri, Jul 8, 2016 at 12:35:15 PM
Wall Base to Face Base
Tue, Aug 12, 2014 at 3:10:04 AM
vehicle turning radius family
Thu, May 30, 2024 at 3:11:35 PM
Page generation time: 10.3019
