134 Users Online (132 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit ROI >> Schedules
Tue, Sep 11, 2012 at 12:19:43 PM | Schedules
JRWIV
I AM NEW TO REVIT AND I AM TRYING TO DEVELOP A FOODSERVICE EQUIPMENT SCHEDULE, THAT DOES NOT INCLUDE ARCH ELEMENTS (DOORS, WINDOWS, COLUMS, ETC. THE ONLY ITEMS/FAMILIES I NEED TO INCLUDE IN THE SCHEDULE ARE CASEWORK AND SPECIALITY EQUIPMENT ITEMS. ANY TIPS?
THANK YOU, JIM WILLIAMS
Tue, Sep 11, 2012 at 12:49:51 PM | Schedules
jlights
3 Stars: 2 Votes
You need to use a filter in your schedule to tell it to only show the items that meet the filter criteria. Check in the properties of the schedule under Filter and set up a filter that makes sense for you. There are many options. One way is to make a shared parameter called Food Service Schedule and add it to all the families you want to show in that schedule, as well as to the schedule itself. (It doesn't have to have a value in the value column). Then set the schedule filter to Parameter: Food Service Schedule / exists, and only those families containing that paramter will show in the schedule. BTW you can make the Food Service Schedule parameter a hidden field (on the format tab of the schedule properties) so it doesn't display.
jlights
Tue, Sep 11, 2012 at 1:30:43 PM | Schedules
JRWIV
THANK YOU FOR YOUR HELP. I WILL TRY YOUR SUGGESTION.
multiple schedules
Tue, May 1, 2012 at 1:04:43 PM
Schedules for Information In Schedules HAHA
Mon, Feb 13, 2012 at 12:08:13 PM
Schedules on multiple sheets
Thu, Apr 27, 2006 at 11:02:00 PM
Large number of schedules
Mon, Jun 20, 2011 at 12:56:19 PM
Area Schedules showing Metric and Imperial
Thu, May 28, 2009 at 11:49:30 AM
Page generation time: 0.4346
