Forums >> Revit Building >> Technical Support >> Property Dialog Box Scroll Bar annoyance
41 Posts No Rating |
I am experiencing this really annoying response from the scroll bar on the Property Dialog box on Revit Architecture 2013.
If I scroll down to, say, the area with the phases at the bottom, and then move my mouse outside the Properties dialog box, the scroll will bounce the display back up, making me have to re-scroll down again if I want to see where I was again, as though I scrolled back up to where is was before even though I haven't. Drive me nuts.
Anyone else experienceing this, and better yet...fixed the problem?
We all experience this - no fix that I have ever heard of.
8 Posts No Rating |
Someone figure this out! This is super annoying.
Folks, Please remember that we are NOT AutoDESK so complain here is OK if you just want to vent. But if you want Revit to change, send your complaint to AutoDESK.
1 Posts No Rating |
Autodesk have acknowledged that there is an issue with the scroll bar in the PP. Although there are no details, I would say it's either a Windows Update issue and/or a .NET 4.5 one, as the same issue affects REVIT 2013 and 2014 (at least). The Autodesk development team are working to resolve this. We have just had REVIT 2014 Update Release 2, so hopefully Update 3 is not too far away that includes this fix. No doubt REVIT 2013 will get an update as well.
Not appropriate to put links here but google "2014 jumping screen an other graphics issues" for some more detail.
Hope that's helpful for those being bugged with this
Revit Structure 2011 Properties Dialoge box annoyance |
Wed, Sep 7, 2011 at 10:02:36 AM
Revit 2015 resolution issue |
Sun, Apr 12, 2015 at 10:34:52 AM
deed data dialog box is different |
Fri, Apr 23, 2010 at 4:14:54 PM
REVIT RENDER QUALITY SETTINGS DIALOG BOX |
Thu, Dec 18, 2008 at 11:04:04 AM
Revit Dialog Box When Opening |
Thu, Feb 25, 2016 at 9:32:50 PM
Members: | 2105729 | Objects: | 23178 | Forum Posts: | 152305 | Job Listings: | 3 |
