73 Users Online (72 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> Automatic Sheet Counting Parameter
Mon, Sep 10, 2012 at 1:53:36 PM | Automatic Sheet Counting Parameter
Mboyer
I'm setting up a project which will have several hundred sheets when all is said and done.  We have a unique Sheet number that is tied to a fixture name.  For instance Sheets will have names such as CO-11.0, CO-11.1, etc.  What I'd like to have in addition to this sheet number is a page number that once can reference to find their way in the set.  So Sheet CO-11.0 would be Page #125.  Make sense?  The question is, is there a way to create a shared paramter that would auto populate this page number as it relates to the order in the sheet listing?  I've been abel to create a manual version of this, but apparently, we could be adding sheets to departments (this is where the CO came from) throughout the project and manually inputting this page number could become a nightmare.  I've added a snapshot of how this would appear in the Title Block.
Mon, Sep 10, 2012 at 2:01:07 PM | Automatic Sheet Counting Parameter
A manual one
http://revitrocks.blogspot.com/2010/02/add-sheet-counter-to-revit-title-block.html
An automatic one:
http://www.kiwicodes.co.nz/Downloads.aspx
Mon, Sep 10, 2012 at 2:34:17 PM | WWHub
Mboyer
Quoting WWHub from 2012-09-10 14:01:06
The "Automatic" link results in "Page could not be found".
"An automatic one:
Mon, Sep 10, 2012 at 2:52:50 PM | Automatic Sheet Counting Parameter
Sorry - it looks like they only had it for 2010.  I suggest you email them.
Mon, Sep 10, 2012 at 3:00:59 PM | Automatic Sheet Counting Parameter
Mboyer
Will do, thanks for posting.
Automatic Sheet Numbering
Tue, Aug 3, 2010 at 4:45:53 PM
walkthrough counting numbers on the right top of the image
Fri, Sep 12, 2008 at 6:31:40 PM
Numerate 'Sheet Number' parameter for match line family
Mon, Apr 28, 2014 at 10:17:52 AM
View List doesn't have parameter to show them in order of number on sheet?
Fri, Aug 26, 2016 at 2:48:11 PM
Sheet list showing previous revisions...
Tue, Nov 15, 2011 at 2:18:29 PM
Page generation time: 2.2411
