24 Users Online (22 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Crazy Nested Family Error 2013
Fri, Sep 7, 2012 at 8:29:29 AM | Crazy Nested Family Error 2013
JDAGEN
I am wondering if anyone has run into this error in 2013.
Background workflow: The project is a residential apartment building. We create link files for each apartment unit type and link them into the overall apartment unit plan. In early design we had all of the apartment units in one project file. When we were finished designing the unit and ready to creat the link files and the overall apartment plan, we grouped the units and used the create link file froom group feature.
We use Revitworks door families with nested door families.
I am not sure that the create link file from group was responsible for the crazy error but here is the error. Each unit file has about 83 total families: doors, windows, casework, pluming, furniture, eqipment/appliances etc. Our unit files ballooned to 150 MB+. We discovered all 83 families had 2 or 3 door families nested into them. It is nearly impossible to think someone manually opened each of the 83 families and manually loaded in the door families. Has anyone else seen or heard of anything like this happening before? Is there a feature that loads a family into all fmilies in a project - not just the ones that are opened and check with the typical check box when you edit and reload a family?
THANK YOU for your help in advance!
Fri, Sep 7, 2012 at 9:08:25 AM | Crazy Nested Family Error 2013
TKennedy
4 Stars: 7 Votes
I've seen something similar happen once, but it involved the Parameter Jerk addon. Whenever I'd use the workaround to
load parameters into an in-place family, those families would somehow end up in an other family I opened for editing
from the project.
Fri, Sep 7, 2012 at 1:57:50 PM | Crazy Nested Family Error 2013
quinn
Were the buildings before you grouped them already linked files?
Fri, Sep 7, 2012 at 6:16:28 PM | Crazy Nested Family Error 2013
JDAGEN
No, they were not linked files before grouping. We have sucessfully recreated the phenomonon. It appears the converting the automatic convert group to link feature is the offending culprit. Has anyone else experienced this??
Fri, May 17, 2013 at 3:52:51 PM | Crazy Nested Family Error 2013
JDAGEN
Here is the note from Autodesk. We are continuing to have this problem and it is contqagious. Once a family ot project file is corrupt, no matter how much you clean and purge it will replicate:
Thank you for choosing Autodesk Support.
I understand after grouping elements in your Revit 2013 project, converting the group to a link, and then editing some of the families in the converted link, you have found that the families contain unexpected nested families from categories you would not expect (e.g. Casework and Furniture).
Thank you for the initial information on this issue, and the files. I have found that this issue was recently logged with our developers (for another user). It looks like projects created with Update 1 or later, do not exhibit this behavior.
Note: I am also able to reproduce this behavior in the 2014 software (with the existing project file).
I am waiting for an update from our developers on this issue, and I will let you know when I receive it.
Best regards
Error in family
Tue, Oct 24, 2017 at 9:28:59 PM
nested family rotation
Tue, Sep 3, 2013 at 1:25:42 PM
Trouble with Array Parameter within a nested family
Wed, Sep 12, 2012 at 5:19:17 AM
Controlling visibility of nested families in familes with multiple types
Mon, Jan 6, 2014 at 10:37:46 PM
scale nested family within a family (2017)
Wed, May 3, 2017 at 5:28:44 PM
Page generation time: 1.1982
