38 Users Online (36 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Mass visibility
Thu, Sep 6, 2012 at 10:01:29 AM | Mass visibility
KHAJG
I created a mass plane to generate a wall by face. In the same project, I created some masses to represent actual piers (because they have irregular stepping geometry). Is there a way to show some masses (i.e. the piers) and hide other mass (the plane used to generate the wall)?
Thu, Sep 6, 2012 at 10:23:07 AM | Mass visibility
3.5 Stars: 395 Votes
Why use a mass for the piers when you could have used an in-place family in the right category?
Thu, Sep 6, 2012 at 10:41:23 AM | Mass visibility
KHAJG
WWHub, for typical piers, I did use an in place family (generated from a column rft template). I used a mass for this because of the irreglar geometry at the top, pleas see the attached elevation view of the pier. Typical piers are extrusions of a plan profile, so I thought it was not appropriate for this particular application. Maybe there's a way to do this using the in-place family that I'm not aware of?
Also, is the massing tool not typically used for representing actual phyical elements?
Conceptual Mass Project Space Visibility
Fri, Jul 15, 2011 at 1:46:11 PM
adding mass in family editor or in place family creation
Thu, Nov 23, 2006 at 9:52:52 AM
How do you make a parametric mass with dimensions and void visibility and volume
Mon, Nov 23, 2015 at 10:03:27 PM
Cutting a section through a mass
Sat, May 16, 2020 at 4:21:54 AM
Visibility Control for Imported CAD Models
Fri, Sep 10, 2010 at 12:49:06 PM
Page generation time: 0.4066
