Forums >> Revit Structure >> Technical Support >> Need help with PAT File URGENT!
1 Posts No Rating |
Greetings
I have been trying to download Pat Files from RevitCity to import to my Revit2012, but nothing has been download. Can someone help me urgently?
Can't see any problem, I just download a couple of Pat. families and works great.
In that family click on "Download Now" button but If your download does not begin in 15 seconds, click on "Click Here" button to download.
You don't import these directly into Revit. You have to save the pat file then create a custom fill pattern in revit and load that file.
downloading pat files on here is sometimes tricky depending on your internet browser, I think its because pat files are just text files. After you hit download and get to the "thanks for downloading screen"; click the button I've circled in the attached image. For me, this opens up the text document in my google chrome browser. Now select all the text, Ctrl+C to copy, then open up notepad and Ctrl+V to paste. Now just save the file, be sure to give it the .pat extension. Now you should be able to import it into your Revit Project.
I'm not saying this is the best way but it should work in a pinch.
Import PAT File |
Tue, Dec 14, 2010 at 9:42:43 AM
Need help with a PAT file |
Thu, Sep 29, 2011 at 12:55:36 PM
.pat file |
Mon, Aug 26, 2013 at 2:56:05 AM
pat file in revit 2010 |
Mon, Mar 1, 2010 at 2:00:08 AM
help its urgent |
Thu, Dec 19, 2019 at 6:19:26 AM
Members: | 2115921 | Objects: | 23193 | Forum Posts: | 152301 | Job Listings: | 3 |
