42 Users Online (41 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Material Tag ??Override/Hack??
Thu, Aug 30, 2012 at 2:25:33 PM | Material Tag ??Override/Hack??
grmorris
I've wondered about this one for a while..
I'm sure I'm not the only person who has had this happen, you get a project all tagged up and a material change occurs, like an update in the brick color, so you update the material, and now all the tags that had already been placed revert to "?"  until you retag or drag the leader off the item and back on... the problem is that sometime we miss these tags and I relly hate when I go through drawings and find those darned "?"'s on the drawings instead of the correct information, so what I';m wondering is, does anyone know how to make the material tags change color like if they are no longer associated to a material or simply are jsut showing a "?" instead of the material indicated whether one has been given a description or not?
Thu, Aug 30, 2012 at 2:35:23 PM | Material Tag ??Override/Hack??
3.5 Stars: 395 Votes
I want to see this problem fixed as well.  Have you looked at it in 2013 yet?   I have not.
I have seen several problems with 2012 and we are trying to move everything to 13.
Material tag and doors
Mon, May 29, 2006 at 5:04:07 PM
material tag
Tue, Jun 9, 2015 at 8:49:15 AM
no material tag in metric library
Wed, Aug 24, 2016 at 2:02:51 PM
material tag schedule problem
Sat, Mar 25, 2017 at 7:50:36 AM
Can't add shared parameter to material tag?
Mon, Jan 21, 2008 at 5:58:33 PM
Page generation time: 0.5765
