134 Users Online (132 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> 2nd floor isn't visible in project browser
Mon, Aug 27, 2012 at 12:53:53 PM | 2nd floor isn't visible in project browser
SooRabid
Sometime durring my project my 2nd floor disappered from the browser. I shows up in the elevation veiw but not in the browser. Any ideas on how to fix this? Thanks!!!
Mon, Aug 27, 2012 at 1:05:24 PM | 2nd floor isn't visible in project browser
Just because you have a level in the elevation doesn't mean you have a corresponding floor plan in the browser.
What color is the target on your level line?  Blue indicates it has an associated floor plan.  Black means it has none.
Mon, Aug 27, 2012 at 1:12:18 PM | 2nd floor isn't visible in project browser
SooRabid
the line is black
Mon, Aug 27, 2012 at 11:45:11 PM | 2nd floor isn't visible in project browser
rinesh355
rinesh355 Avatar
4 Stars: 5 Votes
go to
view/plan view/floor plan   select 2nd floor plan and ok
then 2nd floor appered in project browser
Tue, Aug 28, 2012 at 2:26:39 PM | 2nd floor isn't visible in project browser
revitape
revitape Avatar
4.5 Stars: 9 Votes
FYI, this most likely happened if you "copied" or "arrayed" your level lines up rather than "drew" them using the Level command. They don't automatically get created in the browser if you do it that way.
Rinesh's answer is the solution in case that happens.
High quality modern Revit furniture!
www.therevitcollection.com
The Revit Collection: High Quality Revit Families | Revit Furniture
Thu, Feb 27, 2014 at 6:20:16 AM | 2nd floor isn't visible in project browser
Turan
Is there someone who can help me, I can not see my house in building elevation, only the south side. How can I make it visible in the north, east and west?
Thu, Feb 27, 2014 at 7:39:10 AM | 2nd floor isn't visible in project browser
Click on your elevation marker and pull the view range to include your elements.
Please read about elevations in your HELP.
Fri, Feb 28, 2014 at 9:55:03 PM | 2nd floor isn't visible in project browser
Warchitect
4 Stars: 5 Votes
make sure your elevations and floor plans are all the same phase, like existing or new, because that willl change what is displayed.
Project Browser Sorting Order Question
Thu, Jul 28, 2016 at 5:01:53 AM
2nd Floor View Range
Sat, May 29, 2004 at 5:10:05 PM
level not visible in project browser
Wed, Apr 11, 2007 at 6:09:32 PM
Create sub menu in Project Browser Floor Plan Views
Tue, Jan 1, 2013 at 8:34:41 PM
Visibility of 2nd Floor in REVIT 2011
Sun, Nov 21, 2010 at 8:51:11 PM
Page generation time: 2.3999
