42 Users Online (40 Members):
Forums >> Revit Building >> Technical Support >> Hi -I am new here just a small question and I know people have it -
10 Posts No Rating |
I am trying to make an independent view of a certain plan in Revit 2012 but the independent view option is grayed out and there seems to be no way- if I use duplicate then the changes are replicated ? Please help what can be the way out of this mess.
You want to duplicate the view either with or without detailing. You don't want to duplicate as a dependent view.
Make independent is a tool to copnvert a dependent view into an independent view.
Edited on: Wed, Aug 22, 2012 at 7:15:34 AM
I want to create a version of the floor plan as another option- in a way that that the changes made to one of them donot affect the other one at all ?If I duplicate it with or without detailing and then do a few changes in the wall-layouts it starts aftecting my earlier floor plans as well!
If I convert it into a dependent view and then make it independent will it allow me to make changes to this independent view that are not reflected in the dependent view ?
This has nothing to do with views. It sounds like you don't understand what Revit is. It is a 3D program. If you change any 3D element, it changes that element in any view it is in.
Dependent views - change/add any 2D item and it shows in the dependent & host view.
Duplicvated views - all 2D elements are independent.
If you want to change 3D elements independently, you have to use Design Options.
Thank you .I used revit a lot before from 2007 to 2009 on a few projects but am completely new to changes made in this newer version. Anyways thanks a lot.
Small question |
Tue, Aug 5, 2014 at 7:44:26 AM
Looking for small children Revit rendering images............................... |
Tue, Dec 30, 2008 at 5:31:05 PM
putting people in a walkthrough |
Fri, Jan 25, 2013 at 12:20:05 PM
Basic Material Question |
Thu, Mar 8, 2012 at 1:01:40 AM
Where are the people? |
Sat, Jun 21, 2008 at 6:19:09 AM
Members: | 2022388 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
