51 Users Online (50 Members):
Forums >> Revit Building >> Technical Support >> Exterior Wall Recesses
3 Posts No Rating |
I'm trying to create EIFS panel in brick wall. Needs 4' wide rectangular bottom with 2' radius arch top.
It also calls for soldier brick forming a 180 deg. eyebrow top.
Any hints will be helpful Thanks.
![eldados Avatar](user_avatar/6083.jpg)
![4.5 Stars: 8 Votes](/images/stars_4.5.gif) |
create it as an external generic model wall base, you can assign parameters for the arch top (if you want to)
as well assign the brick material to the arch.
it will be a combination of solid and void extrusion...
HTH
recesses in slabs |
Thu, Sep 29, 2005 at 3:33:42 AM
Wall Recesses |
Fri, Jul 9, 2010 at 9:49:00 AM
Recesses & Vertical Reveals |
Mon, Dec 22, 2003 at 4:26:56 PM
Exterior finish on wall not exterior enough... ? |
Fri, Jun 3, 2011 at 8:44:28 PM
roof detail after exterior wall |
Thu, Apr 1, 2010 at 11:34:56 PM
Members: | 2022352 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
