Forums >> Revit Structure >> Technical Support >> Controlling the leader line in a floor tag
4 Posts No Rating |
My flooris highlighted in blue. How do I control the arrowhead of my floor tag(at center of the image) to place it where I want it to?
When I click on my floor tag, it only lets me control the grip in the middle of the leader line, not the arrowhead.
Edited on: Mon, Aug 20, 2012 at 1:54:47 PM
Use free end.
4 Posts No Rating |
Thanks.
4 Posts No Rating |
How do u add more arrowheads on the same floor tag?
You don't ... you have to add another one but if you move the new one over top the other one, it will snap right over it.
1 Posts No Rating |
what does "use free end" mean I'm having this problem as well
Revit's tags automatically goto the center of the edge of floors, ceiling and roofs, it goes to the center of walls vertically or horizontally in plan and it goes to the placement center of families. This location can not be moved but after placement, you can click on the tag and look at the options bar and switch from attached to free end. The leader will drop to vertical and you can now place it and the tag anywhere.
You can set the tag to free end before you place it, then you can hover over the object and tab select it ... just change the settings on the option bar.
Sometimes the small things .......
I have been avoiding tagging forever because i didn't know this
Leader Line Line weights |
Sat, Feb 7, 2009 at 10:47:58 AM
Positioning the leader on a tag. |
Thu, Aug 6, 2015 at 12:16:40 PM
Manipulating the Leader Line |
Mon, Jan 2, 2012 at 11:05:15 AM
Leader Line Origin in Ceiling Tag |
Tue, Jun 28, 2011 at 7:28:13 AM
Leader line position from Room tag |
Thu, Aug 9, 2007 at 6:44:39 PM
Members: | 2100971 | Objects: | 23173 | Forum Posts: | 152292 | Job Listings: | 3 |
