Forums >> Revit Systems >> Technical Support >> Wall Component diferent height
5 Posts No Rating |
Is there a way to have a wall component set to different height from other components within a wall type
I believe you are talking about this: "Allowing Layer Extension"
http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/0328-Build_th328/0330-Architec330/0331-Walls331/0336-Modifyin336/0347-Working_347/0350-Modify_T350
5 Posts No Rating |
Thanks Typhoon, thats exactly what I needed, however when I am in preview section view I am able to highlight bottom of wall, but cant drag it. If I highlight top of wall, I can drag it up or down, however the other components adjust with it. I have unlock the rag and the others are locked.
Did you UNLOCKED the botttom of that wall like you did to the TOP?
5 Posts No Rating |
Finally sorted. I was trying to move the line of the component in wall editor preview mode. After unlocking, then closing editor, I opened wall section and was able to move the component.
how do wall with diferent width at the beginning in in the end? |
Wed, Mar 2, 2011 at 8:48:35 AM
2d detail component in 3d wall-based electrical family |
Tue, Sep 27, 2011 at 10:17:33 AM
2015 wall height |
Fri, Jul 10, 2015 at 9:17:03 AM
images when print have a diferent colors! why? |
Wed, Dec 10, 2008 at 11:09:49 AM
component with material and recess wall |
Thu, Sep 10, 2015 at 7:22:24 AM
Members: | 2102386 | Objects: | 23173 | Forum Posts: | 152296 | Job Listings: | 3 |
