59 Users Online (57 Members):
Forums >> Revit Building >> Technical Support >> How do you get rid of old revision clouds?
1 Posts No Rating |
How do you get rid of old Revision cloud. when adding a new revision I cannot get rid of the old one . Any tips ?
In your revision setup, the last column on the right is where you set what is to show for eack revision. Nothing, Rev tag only, Rev Tag and cloud.
![AbsoluteBIM Avatar](user_avatar/255025.jpg)
![3.5 Stars: 3 Votes](/images/stars_3.5.gif) |
under the View Tab, sheet composition, revions
make sure the the 'issued' box is unchecked. You can't make any changes to revisions that have been issued. Then just select the cloud and hit delete. If your trying to remove a revision issue all together, you'll have to select it then "merge' up or down with a different one.
Revision Clouds |
Tue, Dec 18, 2007 at 10:52:44 AM
Revision clouds - off on one sheet but not on other sheets - is this possible? |
Fri, Mar 16, 2012 at 9:13:39 PM
shading revision clouds Revit 2017 |
Wed, Feb 28, 2018 at 2:56:28 PM
Revit clouds |
Tue, Jul 29, 2014 at 10:43:12 AM
Revsions & Revision Clouds |
Wed, Feb 20, 2013 at 1:32:13 PM
Members: | 2022537 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
