43 Users Online (40 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revit 2012, cannot import custom pattern from .pat file
Tue, Aug 14, 2012 at 12:03:09 PM | Revit 2012, cannot import custom pattern from .pat file
jarrodpowell
I've created and imported custom patterns from a .pat file in previous versions, but Revit 2012 is not allowing me to import.
I recive the error: 'No "Model" type patterns found', and / or 'No "Drafting" type patterns found', despite the fact that they are called out in the .pat file.
I've imported from this .pat file before, and it contains both custom drafting and model type patterns.
Has anyone encountered this before?
Tue, Aug 14, 2012 at 12:30:16 PM | Revit 2012, cannot import custom pattern from .pat file
Use single files - one per pat, not a multiple file.
Tue, Aug 14, 2012 at 1:17:01 PM | Revit 2012, cannot import custom pattern from .pat file
jarrodpowell
Is this a new requirement for the 2012 software?  As I said, I've used this .pat file previously with no issues.  I don't seem to be able to import any patters, even those I've sucessfully imported into previous projects.
Also - I tried deleting all the additional text aside from the pattern I'm trying to import, to no avail.  Here is the text from the .pat file:
;%UNITS=INCH;%VERSION=3.0
*Illusion 48;%TYPE=MODEL0,  0,0 0, 24, 47.5,.50,  0,8 0, 24, 47.5,.50,  0,16 0, 24, 47.5,.5
Any ideas?
Tue, Aug 14, 2012 at 1:18:03 PM | Revit 2012, cannot import custom pattern from .pat file
jarrodpowell
One more attempt to have the forum correctly dispaly the .pat text:
;%UNITS=INCH
;%VERSION=3.0
*Illusion 48
;%TYPE=MODEL
Tue, Aug 14, 2012 at 7:04:49 PM | Revit 2012, cannot import custom pattern from .pat file
jarrodpowell
Bump
Wed, Aug 15, 2012 at 7:27:25 AM | Revit 2012, cannot import custom pattern from .pat file
That's a bad pat file.  I don't know where you got it but even I can't load it.
Wed, Jan 30, 2013 at 1:36:49 AM | Revit 2012, cannot import custom pattern from .pat file
develocon
develocon Avatar
I'm not sure what the pattern is supposed to look like so I can't debug it for you but.
This works fine, with the addition of 2 commas.
*Illusion 48
;%TYPE=MODEL
0,0,0,0,24,47.5,.5
0,0,8,0,24,47.5,.5
0,0,16,0,24,47.5,.5
I think your problem is the ,0 0, on the first line and the ,8 0, on the second line.
Wed, Dec 30, 2015 at 7:56:07 PM | Revit 2012, cannot import custom pattern from .pat file
jangley
I know this is old but im haveing the same problem with 2014. ive downloaded 3 different stone PAT files one being southernledge stone and try imp0orting them both at drafting and model and it keeps telling me no type patterns found... Ive attacehd the .pat file for reference..
Wed, Dec 30, 2015 at 8:31:19 PM | Revit 2012, cannot import custom pattern from .pat file
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
In the place of mode, type MODEL or DRAFTING. You might need to adjust import scale of the hatch too.
Import PAT File
Tue, Dec 14, 2010 at 9:42:44 AM
Stray Lines in custom Revit fill pattern
Mon, Jul 8, 2013 at 8:02:45 AM
Split Faced CMU model material pattern help???!?!?!?
Fri, Jun 1, 2007 at 2:01:40 PM
Custom Model Pattern from AutoCAD DWG
Tue, Dec 31, 2013 at 12:39:01 AM
Pattern (.PAT) Files
Mon, May 3, 2021 at 4:51:05 PM
Page generation time: 2.1628
