65 Users Online (64 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> What do I lose if I use a floor family to model a flat roof?
Fri, Aug 10, 2012 at 4:04:08 PM | What do I lose if I use a floor family to model a flat roof?
xixiha
Quite tempted to do this, because in the floor family, we can use the deck profile, but in a roof family we can't. What will I lose if I do so?
When I talk with a co-worker about this just now, She suggested I may lose the right to insert a skylight into it, because we can't insert a window in a floor. Sounds quite logic. But when I check the floor based generic family, I found the family type can be changed to window. Did someone have similar experience?
And is there any other feature I may lose if I use a fllor to model a flat roof?
Mon, Aug 13, 2012 at 9:23:35 AM | What do I lose if I use a floor family to model a flat roof?
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
You are correct, and it is actually common to make flat roofs as floors. Yes, you can put windows in that floor if you need to,creating a face-based or floor-based window families. You have the same system of layers of materials, and the same panel for shape editing points.
Edited on: Mon, Aug 13, 2012 at 9:24:00 AM
Planta1 Revit Online Consulting | info@planta1.com
Mon, Aug 13, 2012 at 10:59:20 AM | What do I lose if I use a floor family to model a flat roof?
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
The main difference is the roof thinks it's a floor as far as it's 'category' goes. So it will follow the object style, display, visibility graphics and filter rules of a 'floor' element.
Flat roof
Fri, Mar 20, 2020 at 4:58:57 PM
Trimming roof with roof/floor
Mon, Nov 5, 2012 at 3:27:41 AM
Sloped floor but flat bottom
Wed, May 16, 2012 at 2:52:56 PM
Flat Concrete Tile Roof
Tue, Oct 29, 2013 at 10:31:53 AM
Flat roof with crickets
Mon, Jun 9, 2008 at 3:50:46 PM
Page generation time: 2.4397
