Forums >> Revit Building >> Technical Support >> REVIT 2013 - Export DWG Layers Text File Location
18 Posts No Rating |
I'm in the processing of setting up export standards from revit 2013 to dwg layers. I know where to modify the layer colors, names, etc in Revit but I don't know where the export text file has been moved to or where it goes when I create a new one. Thanks in advance for your help.
Gregory Williams, AIA, LEED AP
Check in: C:\ProgramData\Autodesk\RVT2013\exportlayers-dwg-ISO13567.txt
Thanks for the info. That's the location I tried, but for whatever reason my file is MIA. Does that path change for Windows 7?
For some reason, I found it inside of the Revit Extensions downloaded after the final version of Revit 2013 was released, but here they are. I think they were forgotten about during the initial release.
MDRCCF,
Thanks for the information and the actual files.
I appreciate your help.
For anyone looking for the Revit 2016 location of these files [not true for 2018], here's the path I found on my workstation:
C:\Program Files\Common Files\Autodesk Shared\Extensions 2016\Modules\Tools\DRevitFreezeDrawing\Configuration\
Edited on: Fri, Aug 3, 2018 at 4:48:35 PM
Dwg export: revit 2013 ignoring subcategories |
Thu, Jul 25, 2013 at 8:12:44 AM
Keep .dwg Layers when exporting .rvt to .dwgPlease |
Wed, Feb 24, 2016 at 9:28:00 AM
Export to dwg or dgn. Layers |
Wed, Nov 18, 2009 at 12:04:11 PM
Empty layers in DWG-file. |
Mon, May 13, 2013 at 3:59:05 AM
DWG Export Setup for particular layers? |
Wed, Jul 24, 2013 at 3:22:42 PM
Members: | 2100632 | Objects: | 23171 | Forum Posts: | 152294 | Job Listings: | 3 |
