107 Users Online (106 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> frieze board
Sun, Jan 8, 2006 at 6:54:33 PM | frieze board
framerman
4 Stars: 13 Votes
I can't seem to figure out how to apply a frieze board along the rake of a gable roof. I tried a wall sweep, but that only gives horizontal. Anyone have an idea how to do this? Thanks
Sun, Jan 8, 2006 at 10:12:22 PM | RE: frieze board
eldados
eldados Avatar
4.5 Stars: 8 Votes
CREATE THE PROFILE YOU NEED AND USE HOST SWEEP --> FASCIA... IF THAT DOESN'T WORK, YOU MIGHT HAVE TO USE IN PLACE FAMILY AND SET THE WORKPLANE TO THE ROOF ANGLE... JUST LET US KNOW IF YOU HAVE PROBLEMS WITH THAT... HTH
Integrator
KarelCAD
Sun, Jan 8, 2006 at 10:45:56 PM | RE: frieze board
framerman
4 Stars: 13 Votes
Host sweep is what I've tried, but it doesn't attach to the wall, just the roof edge. However, what I've done is to go ahead and do the fascia on the underside of the gable end and move it to the wall. Works pretty good, didn't know if there was something easier though.
Sun, Jan 8, 2006 at 11:21:02 PM | RE: frieze board
eldados
eldados Avatar
4.5 Stars: 8 Votes
if it works it works! Smile
Integrator
KarelCAD
Roof eave/soffit gabled roof - RAC2008
Fri, Aug 24, 2007 at 7:09:30 AM
Fascia Board Too Long
Tue, Nov 20, 2012 at 10:19:32 AM
Hardie Board Panels
Wed, Sep 11, 2013 at 3:44:36 PM
Modifying walls sweeps
Wed, Apr 30, 2008 at 9:44:16 PM
Timber External Cladding BOard / Weather Board
Wed, Mar 31, 2010 at 10:02:30 AM
Page generation time: 2.1402
