88 Users Online (86 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Window's dimension don't show up in the window schedule
Wed, Aug 8, 2012 at 4:31:30 PM | Window's dimension don't show up in the window schedule
diesellam
I created that window family I mentioned in my earlier posts.
The window type showed up in the window schedule.  But the window dimension didn't.
What's the reason of it?  I know you can enter the dimension directly into the schedule.  But it would be nice if it comes it automatically.  See attached file.
Thanks in advance.
Thu, Aug 16, 2012 at 1:20:31 PM | Window's dimension don't show up in the window schedule
revitape
revitape Avatar
4.5 Stars: 9 Votes
You don't have those parameters (height and width) established in the window family. All that is there is rought height and rought width and for some reason those are set to 555'
so add those parameters in the family, reload into your project, and they will show up in the schedule
High quality modern Revit furniture!
www.therevitcollection.com
The Revit Collection: High Quality Revit Families | Revit Furniture
Fri, Aug 17, 2012 at 4:16:51 AM | Window's dimension don't show up in the window schedule
4 Stars: 202 Votes
"You don't have those parameters (height and width...." - He don't have ANY parameter in that family, I'm wondering how do you change the size of that window if you need to .... diesellam?
Fri, Aug 17, 2012 at 11:44:04 AM | Window's dimension don't show up in the window schedule
sllana
5 Stars: 2 Votes
Here is your window with those parameters added. And dont forget to include the respective fields (width & heigth) in the schedule.
Fri, Aug 17, 2012 at 12:26:13 PM | Window's dimension don't show up in the window schedule
diesellam
OK, I figured out what the problem is.
Now this is my next question,.  I was able to make the width without any problem: meaning when I change the width,
the mullion, glazing, rough opening, all follow the width.
But the height doesn't work that way, what's the reason of it?
See attached file.
Thanks in advance.
Fri, Aug 17, 2012 at 1:34:44 PM | Window's dimension don't show up in the window schedule
I suggest you download the families guide from the autodesk site.  That will show you how to create parametric families and how to use parameters.
Nested window mullions (Generic Models) don't appear in Window Schedule
Wed, Apr 30, 2008 at 11:33:21 AM
Window schedule
Wed, Apr 18, 2007 at 5:28:37 AM
window opening doesn't show in floor plan view
Mon, Oct 3, 2005 at 7:59:16 PM
Window Placement
Wed, Jul 19, 2006 at 10:11:52 AM
Material takeoff - the math doesn't jive
Fri, Sep 8, 2006 at 11:04:30 AM
Page generation time: 2.4320
