90 Users Online (89 Members):
Forums >> Revit Building >> Tips & Tricks >> Different Scales on Titleblock
10 Posts No Rating |
This is a bit of a wishful question, regarding scales in Revit, involving title blocks.
As we know, we can put in a label on a title block and Revit will let us know the scale of the drawings (providing they are the same). How I have mine set-up, I have Scale @A1 - 1:100.I am wondering if it's possible to add a section scale label which calculates the scale at half, so if the document is printed at half-size, automatically it displays the scale for that print size. Example....
Scale @A1 - 1:100
Scale @A3 - 1:200
Which would show up in all drawings, regardless if it's printed at A1 or A3. So is this possible? Or do I have to manually put it in with text?
No way to do this that I know of....
Why don't you have a "stamp" that you can turn on in the titleblock that says HALF-SIZE PRINT
How would you do this stamp?
We have a not for construction "stamp" in our titleblocks. I would think you want something similar.
Note that are stamp is cocked so that it stands out. The visibility of the stamp is set with a parameter. To set the parameter for printing, pick any instance of the titleblock, then pick select all instances in the project and set the switch.
Edited on: Tue, Aug 7, 2012 at 8:04:53 AM
Revit 2009 titleblock |
Mon, Sep 12, 2011 at 3:53:08 PM
Titleblock resized after export |
Fri, Feb 7, 2014 at 8:40:39 AM
Getting Titleblock in centre of page |
Tue, Mar 30, 2010 at 7:13:05 AM
Titleblock question |
Thu, Jul 2, 2009 at 4:23:14 PM
I want to take printouts of sheet sets in scale. PLEASE HELP ITS URGENT |
Sat, Jun 4, 2011 at 5:32:23 PM
Members: | 2017305 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
