55 Users Online (54 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Different Grid Bubble for different scale views?
Mon, Aug 6, 2012 at 1:02:16 AM | Different Grid Bubble for different scale views?
satheeshbabu
Hi,
I want to use different size Grid Bubble for different scale view.
If change the size of the grid bubble, It is affecting all the views.
Is there any workaround to get the different grid bubble for different scale views?
Thank you.
BR,
S.Satheeshbabu
Wed, Aug 8, 2012 at 11:19:30 AM | Different Grid Bubble for different scale views?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Grid bubbles are not view specific so if you change one in a plan view it will change it everywhere else that the grid show up in.
Wed, Dec 11, 2013 at 2:37:47 PM | Different Grid Bubble for different scale views?
MsmithCAD
you could create a different family for the different size, then create a duplicate "large" type fo the title using that family
Wed, Dec 11, 2013 at 2:56:34 PM | Different Grid Bubble for different scale views?
3.5 Stars: 395 Votes
Grid line types are NOT view specific either and you can't have to grids with the same designation so I doubt this will work.
Thu, Dec 12, 2013 at 5:42:13 AM | Different Grid Bubble for different scale views?
archigrafix
5 Stars: 4 Votes
Grids are have fixed print size globally. That ensures that all your drawings have similar simbology - for instance when you combine different scale drawings (different views) in the same sheet, the grid bubles are identical.
If you have to use different sizes (for whatever reason), you can link a empty revit file just with a copy of your grid system and different grid simbology (different buble types) to specific views (hidding also the grid on your main file). You could also manually draw grids and bubles with annotations. But these "solutions" are obviously not the revit way of doing things - and you have to remember that as they are manually done, you can face inconsistency problems ahead.
Good luck.
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
Grid Bubble Control in Different Views
Tue, Jul 10, 2012 at 7:22:19 PM
Grid Bubble formatting between projects
Sun, Oct 26, 2014 at 8:33:04 AM
problem with grid bubbles when printing in smaller scale
Fri, Sep 28, 2007 at 2:02:01 AM
Column grid text too wide to fit in bubble
Thu, Jul 1, 2010 at 8:32:06 AM
Grid Bubble Trouble Revit 2015
Fri, Sep 25, 2015 at 7:25:43 AM
Page generation time: 0.5669
