64 Users Online (61 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Exception in Visability Graphs
Fri, Aug 3, 2012 at 1:35:30 PM | Exception in Visability Graphs
cboersen
I have a very complicated plan where I want to make all the wall light and trasparent accept for one.  I went into visabilty graphics and click the boxes to make the walls light and trasparent ... so that worked fine.  I cannot figure out to exclude the one wall I want to show in the normal way.  Is there a way to do that?
Fri, Aug 3, 2012 at 3:29:11 PM | Exception in Visability Graphs
AbsoluteBIM
AbsoluteBIM Avatar
4 Stars: 4 Votes
Select the wall, right click, override graphics, by element
Then you can make it look anyway you want.
Mon, Aug 6, 2012 at 6:59:55 AM | Exception in Visability Graphs
cboersen
Select the wall, right click, override graphics, by category (same as opening visabilty graphics) overrides "Select the wall, right click, override graphics, by element".  In this case that does not work, at least not that I can tell.  Let me know if I am missing something.
Mon, Aug 6, 2012 at 7:58:57 AM | Exception in Visability Graphs
You are correct, you can not set the wall to solid after it has been set to transparent.  Instead, you can
  1. Select all other walls and over-ride graphics in view setting them transparent.
  2. place this one wall in a workset and control it separately.
Mon, Aug 6, 2012 at 8:05:59 AM | Exception in Visability Graphs
cboersen
Oh ... thats a good idea, I did not think of that.
Because it was a special wall I was able to use a filter to set all but that one wall type to half tone and transparent.
Visability parameter for dimensions
Tue, Jul 31, 2012 at 12:17:05 PM
Visability/ graphics
Tue, Mar 25, 2008 at 1:40:47 PM
visability problems
Thu, Feb 1, 2007 at 6:57:59 PM
visability problems
Tue, Jan 30, 2007 at 10:44:00 PM
Visability Parameter is greyed out
Sat, Jan 24, 2015 at 4:10:27 PM
Page generation time: 12.6623
