27 Users Online (26 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> mess of lines
Fri, Aug 3, 2012 at 9:08:26 AM | mess of lines
frifer
5 Stars: 4 Votes
hi guys!
whats the correct way to work when the drawing gets messy? i am not even half way throgh the drawing and have a lot of lines and quotes. sometimes i hide them but if i need one that is hidden then it will reset all lines and then i have to rehide them one after the other..
thanks
Check out my new Renderlist add-in to render multiple views in sequence overnight! Get it here and remember to leave some feedback Shadey http://www.revitcity.com/forums.php?action=viewthread&thread_id=28381
Fri, Aug 3, 2012 at 9:51:15 AM | mess of lines
I assume these are reference planes in the family.
Why do you have som many?  Not everything needs a reference plane.  I try to keep mine under 8-10 and those are mainly for parametric needs or strong references for dimensioning in the project.
Do you name your reference planes?  If you don't think they are important enough to name, then you don't need them.
Fri, Aug 3, 2012 at 9:57:07 AM | mess of lines
frifer
5 Stars: 4 Votes
yes they are all reference planes and i use them only where i have parameters that change based on the type.
didnt know that i can rename them! wil lcheck it right now!
Fri, Aug 3, 2012 at 11:01:32 AM | mess of lines
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
To avoid all that visual clutter with reference planes, you could subdivide the family into smaller, nested, families, each of them with its own set of reference planes.
Planta1 Revit Online Consulting | info@planta1.com
Pads mess up topography?
Sun, Oct 26, 2014 at 8:34:41 AM
Elevation Levels Mess
Thu, Jun 26, 2008 at 11:53:14 AM
Missing level lines in elevation
Wed, Nov 16, 2005 at 2:57:01 AM
Can you convert model lines to detail lines?
Wed, Mar 31, 2010 at 12:45:24 PM
Model Lines to Detail Lines???
Sun, Aug 31, 2008 at 9:24:51 PM
Page generation time: 0.7943
