31 Users Online (30 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> yes/no formula
Fri, Aug 3, 2012 at 1:00:36 AM | yes/no formula
vidhikholia
Trying to find a formula for this situation....
AA, BB & CC are parameters
when CC is turned on, BB and AA turns on;
when BB is turned on, AA turns on and CC turns off;
when AA is turned on, BB and CC turns off.
Fri, Aug 3, 2012 at 2:29:01 AM | yes/no formula
gebber
gebber Avatar
5 Stars: 4 Votes
there are many ways easiest way I gues is;
select AA, in the properties go to, visible and click the box @ the end of the line.
ad parameter and call it AA and set it as a visibility .
do the same with BB & CC.
Whebn these 3 parameters are set go to the Family Types, under family types choose new and call it AA, make sure you check the box with AA and uncheck the boxes BB & CC. repeat this for BB & CC.
load the family in a project to see the results
(in the family you can check wich ellement shows by checking if it has a grey or black outerline)
Fri, Aug 3, 2012 at 9:35:16 AM | yes/no formula
frifer
5 Stars: 4 Votes
hi! not sure of what i am saying beacuse i am pretty new with revit! Smile i think that your request creates internal conflicts because when CC is turned on it turns on AA wich then turns off CC.. so basically you cannot turn on CC..
what i would do is create three more variables. (on off switches) like this:
SwitchAA
SwitchBB
SwitchCC
AA
BB
CC
and would put these formulas for these:
SwitchAA: if (OR(SwitchBB , SwitchCC), 2<1,1<2 )
SwitchBB: if (OR(SwitchAA , SwitchCC), 2<1,1<2 )
SwitchCC: if (OR(SwitchAA , SwitchBB), 2<1,1<2 )
AA: if(OR(OR(SwitchAA, SwitchBB),SwitchCC),1<2,2<1)
BB: if(AND(OR (SwitchBB, SwitchCC), NOT SwitchAA) ,1<2,2<1)
CC: if(AND(AND(OR(SwitchCC, SwitchBB), NOT SwitchAA),NOT SwitchBB),1<2,2<1)
i did not test it so it might need a few modifications. hope you get what i mean. if you try to explain better what you are trying to achive it might be easier to help... Smile
regards
Igor
Check out my new Renderlist add-in to render multiple views in sequence overnight! Get it here and remember to leave some feedback Shadey http://www.revitcity.com/forums.php?action=viewthread&thread_id=28381
Fri, Aug 3, 2012 at 9:38:41 AM | yes/no formula
frifer
5 Stars: 4 Votes
just tried, it does not work. its a circular reference.. Sad sorry
Fri, Aug 3, 2012 at 9:43:59 AM | yes/no formula
frifer
5 Stars: 4 Votes
here we go.. tested and works.. Smile hope it is what you need! Smile
Sun, Aug 5, 2012 at 6:21:09 PM | yes/no formula
vidhikholia
@gebber: I already did that but wanted something which would be automatic like with formulas. Thanx for the reply.
@frifer: ur formula worked like a charm! thanks alot! Smile
Kind Regards,
Vidhi
Mon, Aug 6, 2012 at 4:02:28 AM | yes/no formula
gebber
gebber Avatar
5 Stars: 4 Votes
@ frifer nice formula,
Anyhow, what advantage does this give you?
Now the family contains calculations wich slow up the model and costs a lot of extra time, besides when a 3rd party has to work with it it takes a lot of time to figure out how this works.
This is why I try to keep it as basic and simple as I can.
I agree it's the most beautifull way to create it like frifer discribes.
Mon, Aug 6, 2012 at 4:28:19 AM | yes/no formula
frifer
5 Stars: 4 Votes
i would create it with a single parameter insted of the 6 yes/no boxes. i posted that as solution since it was the request.
so instead of having all the switch variables etc i would use a integer that can be a value between 1 and 3 and based on that change all the other variables.
it avoids having multiple checkboxes on at the same time while only one is actually changeing something because it has a higher priority.
so, if AA BB and CC are just some variables in the model and not the checkboxes:
Switch on number (is an integer between 1 and 3)
AA: if(Switch on number = 1, 2345 mm, 6541 mm)
BB: if(Switch on number = 2, 2645 mm, 1541 mm)
CC: if(Switch on number = 3, 345 mm, 641 mm)
in case of switches its even easier:
Switch:  if(Switch on number = 1,1<2, 2<1)
its easy tu understand, to use, and to implement.
Using schedule total in formula?
Fri, Apr 4, 2014 at 10:29:50 AM
One family parameter has formula one has none
Wed, Jun 25, 2014 at 1:05:54 PM
Parameter Formula
Fri, Mar 5, 2010 at 12:09:09 PM
need help with a formula for my calculated value
Thu, Jan 30, 2014 at 1:03:02 PM
Formula Help
Thu, Aug 10, 2006 at 9:34:15 AM
Page generation time: 0.2372
