74 Users Online (73 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> nested families
Thu, Aug 2, 2012 at 3:43:20 AM | nested families
frifer
5 Stars: 4 Votes
Hi guys!
lets say i have a family called "table set"
and two other families called "table" and "chair".
i nest the table and the chair in the "table set" family... do i have to keep the "table" and the "chair" family as a revit file on my harddrive or can i delete the files once they have been nested?
thanks
Igor
Check out my new Renderlist add-in to render multiple views in sequence overnight! Get it here and remember to leave some feedback Shadey http://www.revitcity.com/forums.php?action=viewthread&thread_id=28381
Thu, Aug 2, 2012 at 3:50:23 AM | nested families
4 Stars: 203 Votes
Why don't you try?
You can delete....
Thu, Aug 2, 2012 at 5:31:50 AM | nested families
frifer
5 Stars: 4 Votes
because by trying i might find out the short term conseguences but not the long term ones.. Smile dont know about the connections revit has with other files.. Smile
Thu, Aug 2, 2012 at 7:32:15 AM | nested families
Obviously, linked files have connections.  But for families in the project or shared families, the only connection is that Revit remembers where they came from.  This doesn't really do anything for you except if you modify them, they can be saved to their old location.
This "connection" can really be a problem.  Lets say you have a template you created in 2011 with 2011 families.  You have now moved on to 2013 and you upgraded your template.  Now you want to change the door family by opening it from a project.  When you save it the default path is your 2011 library.  If you don't pay attention and change that, your 2013 family remains unchanged.
Locking nested families?
Wed, Aug 27, 2008 at 12:23:09 PM
13
nested families do not cut
Thu, Jan 14, 2010 at 11:44:55 AM
Door swings with nested families
Fri, Sep 18, 2009 at 1:41:24 PM
Hiding nested families in a project
Thu, Jan 14, 2010 at 10:21:37 AM
turning on/off nested families in host family in different views in project.
Fri, Aug 7, 2009 at 11:11:32 AM
Page generation time: 5.9548
